DaveP
Ive finally decided which FSU camera I like best. My Zorki 1 !! The reason is you have to remove the bottom,set it in a safe place,set the camera on a soft surface, pull the take up spool,insert the leader, slip both film cartridge and spool into the camera via business card, wind on to check that it "takes", replace bottom,set frame counter, pull out collapsible lens, take meter reading with handheld and compensate for filter factor,remove filter and set f-stop,replace filter,wind to first frame,set shutter speed, hold to eye and focus on subject,switch eyepieces to frame subject,...............snap picture.
Ive noticed that when I look through my pictures , I always seem to like the ones taken with the Z1 the best, all that work makes you appreciate the shot more , sort of like"mission accomplished".
