ColSebastianMoran
( IRL Richard Karash )
When this happened to me, it was the lens not closing down.
Test: If exposure is right wide open but bad at f/8.
I habitually shoot 1 stop under when in contrasty situations to avoid too many blown highlights (and have done so for a while) and have noticed when I do not, that the images generally look a little washed out. I had never considered the thought that it might be mis metering or have some other problem. I just figured this is how it is - and coped. I suppose I could check exposure readings against one of my other cameras. But then again I tend to find that I want to under expose (against metered readings) for most cameras as most of them seem to my eye too included to "expose to the right" to the detriment of highlights when shooting in outdoor situations as I usually do.
I don't understand what is supposed to happen when autobracketing is selected, but only 1 frame is chosen. Seems odd that's even possible.
If 3 are chosen, I'd expect -1, 0, +1 or maybe +1, 0, -1. Maybe selecting only 1 frame gives you that +1 EV.
2. I set the metering to mid-range center. My tests showed that spot metering caused too many variations in exposure, and the usual setting, for the entire screen, was somehow also inconsistent on many occasions.
Emperor Napoleon of France who it seems ignored all his correspondence for up to a month, on the principle that nine times out of ten most things if left alone long enough, eventually resolve themselves in one way or another.
