Chriscrawfordphoto
Real Men Shoot Film.
OK, the results are in and they are defenitely too contrasty. Heres what i did:
1:50 Rodinal developer
15ml Ilfostop stopper with 285ml water
60ml Adofix fixer with 240ml water
1 little sprinkle of Adoflo wetting agent
Development: 12 minutes with 2x agitate (gently) every two minutes
Stopper: 1 min, 1 agitation
Fixer: 3 mins, 1 agitation per minute
Washer: several rounds of fresh water at the same temperature (does temp even matter when washing?) until the bubbly from the washer was gone
I would be willing to switch developers but i dont like powder stuff so what developer would you recommend? I liked DDX with HP5 plus btw so i wonder if thats a good combo. Thanks.
You'll probably like DDX. I have not tried it with Tri-X but it gives results in other films similar to Kodak's Tmax Developer, which i have used a lot for Tri-X. It has finer grain than Rodinal.
Do you like the grittier texture that Rodinal gives, but were getting too much contrast? If so, try reducing the developing time. Try 10 minutes. Any developer can give normal contrast IF you don't overdevelop. If you're getting too much contrast, a shorter dev. time will fix it.
If you don't like the grain of Rodinal, try DDX or Tmax Developer, they'll give finer grain.
