Need dev time for HP5+ in HC-110 @ 100 ISO
javimm
6:34 PM
Madrid, Spain
Hi.
My father forgot to change the ISO dial on his Bessa R2M after shooting a roll of Reala and then loaded a roll of HP5+. So I ended up with a roll of HP5+ shot at 100 ISO that I have to develop 😉.
I only use HC-110. According to the massive development chart, 6.5 mins dil H, 21ºC should do it.
http://www.digitaltruth.com/devchart.php?Film=HP5&Developer=HC-110&mdc=Search
Does anybody have any recommendations for developing this roll?.
I usually develop HP5+ shot at 400 ISO with 5 mins, dil B as Ilford recommends.
Thanks.
A long while ago I shot a roll of FP4+ with a lens that had a sticky diaphragm on a sunny day. Meaning: All pictures were severly overexposed. FP4+ and HP5+ can take massive amounts of overexposure so the negs were still very usable.
If the massive dev chart has a solution for you, use it. HP5+ is so forgiving the negs will be fine even when you do standard processing.
I've just developed the roll and came out great!!. A bit less contrasty than the ISO 400 HP5+ rolls I normally develop, which is good. Negs seem to have a greater tonal range than usual. I have to research dil H more, as I know one of its side effects is the extended tonal range although it increases grain.
I'll see when I scan the negs.
Thanks all.
