Need help for Top Ten project :(
dmr
Registered Abuser
7:26 AM
Somewhere in Middle America
I hope I'm not just missing something obvious here ...
Ok, I created a new album called Top Ten.
Then I used the "edit photo" function to copy 2 images into the album, following the instructions.
Then I decided to check it.
The album is there, but there's no thumbnail image that you can click on to access it, as you can the other albums. When I created other albums, the first photo you put in there shows up in that place.
So I go and try to edit the album. There's a space for "Thumbnail for album" but it says "None" and there's no obvious way to enter it. Am I missing something?
For a sanity check I looked at how one of the other albums was set up and it's the same way, but all the others show up a clickable thumbnail for the album.
I think I must be missing something.
Thanks in advance ...
Hello,
I'm not an expert but you may check a couple of things (probably you altready did but ...) to see if it can be fixed:
did you tried to click on My albums >>> Sort photos >>> make album cover (thickin under the photo you want to use for that)?
Otherwise, when you create an album you have to choose if it's private or not ... did you leave no as the default option suggest?
Hope it may help,
ciao 🙂
Thanks, Nico. That did part of it.
I did get a thumbnail to show under My Albums now.
However, when I display it under my photos I get a "image pending approval" thumbnail like this:
Does this require a moderator or bartender to intervene?
Yes, I set it to not private.
Thanks.
