ZorkiKat
ЗоркийК&
- Local time
- 10:45 AM
- Joined
- Jan 26, 2006
- Messages
- 2,070
I have been developing 1+1 D76 in a single reel tank for 30 years and the results came out properly. Same with 1+1 in double tanks- 2 reels and just the capacity needed to fill the double tank.
In fact I often use 1+3 (Ilford's ID 11 alternative dilution) in single tanks, with a single roll. The tank needs 220 ml to fill; at 1+3, stock D76 needed is less than 53mls, the rest is water. Times are extended of course, about double needed for 1+1 dilutions. Time has to be extended as the developer gets more diluted.
Diluting the developer is done for a certain output. One is compensation- when highlights or contrasts need to be tamed. Two is for greater sharpness. D76 at 1+1 does that. But the effects are more obvious when its diluted 1+3. Three is economy- if there are a lot of films to be developed, a diluted 1 shot developer may be more practical.
@Anitasanger: As for the "low contrast" issue- TX developed in 1+1 D76 tends to look lower in contrast than TX developed in straight D76. Could it be that it just looks new to you? You did say that the contrast looks lower than what you're used to seeing. Is this the first time that you used diluted developer? This reaction is quite common for people who are used to 'harder' negatives developed in more vigourous developers.
