Sonnar2
Looks like the E-P1 needs an urgent update.
Understood. But in a market where all in-built optical VFs are wildly inaccurate, an accurate EVF will do. I'm not looking upon this as a direct M-substitute, but perhap as a serious replacement for my Olympus C-8080, which is nice in its own right, but rather big to be taking with me much of the time. And, one can add an optical VF from CV, although one would have to set things up carefully, focal-length-wise (although it would be nice if Panasonic added one or two of their own somewhere along the way).Good as an EVF may be, it will never show more than the frame you're about to capture. So, no projected framelines and seeing outside the frame.. I'd think an optical external viewfinder would still be best..
I wish lenses had distance and aperture scale. It would be "theoretically" easy to find out focus distance since everything is electronically controlled now. Don't forget focusing tabs too!
When the camera is turned off, the focusing could still be disabled but once turned on, depending on the focus ring position, it could electronically focus the lens right to that same spot.
This is interesting by the paradox. The Ep1 arrives everyone castigates it for not having an EVF, and that's the next Panasonic move. Furthermore the general no grip shape is even more pointing to Ep1 jelousy.
Hence that either we at RFF were downright wrong and the EP1 is a great success and is here to stay and point the way, or Panasonic is doing a strange manouvre.
And if Panasonic is leaving the EVF, this means that used G1s' will be looked after in some time at higher prices, unless another manufacturer surprises like Panasonic did with its G1.
Very strange. Or a joke.
Ruben
When you go to the link below, you will see the 1st pic( yes u have seen it many times) that the 45mm lens is a "Leica lens", but the same lens is shown on pic 4 with different label, which said "Lumix G Marco.......Mega OIS"............looks like a fake after all.
http://blog.livedoor.jp/e_p1/archives/51257852.html
where does this put olympus on the m4/3 map if Panasonic can put out better cameras with more features?
