All (
link... see slide 13) digital cameras sensors use CCD detection (
p-dopred MOS capacitors).
However some use CCD detection and incorporate
all of the other electronics required to record a raw file on a single chip. These are CMOS sensors. There are differences in timing circuit designs as well. The chip manufacturing processes are dissimilar. But the conversion of light to electrical charge is always via charge-coupled (CCD) pixels.
The preferred rendering of the M9/M8 is not due to a CCD sesnor because all sensors are CCD devices. However the sensor assembly unit when viewed as a data recording system composed of many components engineered with excellence as the highest priority is a completely different situation.
All of the technologies before the CCD pixel array – IR filter properties, color filter-array bandwidths, micro-lens design – play a role in image aesthetics.
After the data is recorded the parameters used in Bayer demosaicing interpolation algorithms must closely model the properties of the CFA bandwidths to insure rendering and tonality are optimal. It is reasonable Leica cooperates with Adobe to produce the best possible Camera Raw rendering Profile. After all all M9s ship with LR and Lica wisely adopted the DNG file standard.
So eliminating the IR filter cover glass delamination defect was only one aspect of the developing a new sensor assembly.
There is no reason to worry that Leica will not apply the very best
system engineering to the new sensor assembly. After all isn't Leica all about delivering the highest possible quality? Differences in CFA, IR and other technical details could be well-within manufacturing tolerances. It may be impossible to tell the difference between the old and new sensor assemblies.
