Nikon DF and Zeiss lenses
wintoid
Back to film
1:09 PM
Kent, UK
Did I understand right that the DF will prevent you from using the aperture ring if the lens supports CPU control? So Zeiss ZF you can use the aperture ring, but Zeiss ZF.2 you cannot?
Seems a bit strange, not sure if I'm misunderstanding.
With D700 you can set up the camera to use the aperture ring instead the controls on the body. I would guess, Df will do the same thing. Why not.
