huntjump
... or care? ...
ouch sparrow. haha clearly a 2 page discussion on it would say otherwise (for some)
... or care? ...
No, I'm not convinced by any of these theories.
It seems to me there was some optical/photographic purpose Barnack had in mind when he created the hockey stick infinity lock on those early cameras.
When interchangeable lenses were introduced the infinity lock moved to the lens mount, because it had to. And then it gained the other purposes which have been mentioned - but that didn't change its *prime* purpose, the reason it was created - which we don't seem to know!
Regards - David
For my use, I find that keeping the Summarit on infinity lock, I always have a reference point from which I turn the lens in only one direction to the desired position...which is a very short distance, btw.😉 Just one less thing to think about and it becomes second nature very quickly. At my age, I like to keep it simple.
Quote:
Originally Posted by t6un
Additionally, infinity may be the safest setting to avoid burning pinholes into the shutter.
Um, I think we'll give you the Friday afternoon bonus for this one ;-)
Ever owned or used a fixed-lens Leica? The infinity lock really does make it a LOT easier to pull out/collapse the lens.
But I'm still going to screw the lenses in when set to 1m as that way the RF cam isn't being hit and knocked about before the 39mm threads engage.
Lenses in collapsible mounts must be pulled out and locked in the bayonet catch, their focusing lever in the infinity position, before being screwed into the changing flange.
My reasoning is based on the fact that the first shutter curtain of my Leica is ca 2,8 mm closer to the lens mount than film. Accordingly, the sun will be focussed at the curtain when the lens is extended 2,8 mm from infinity position? With 50mm lens this happens around 1,2 m focussing distance, this is the best setting to fry the shutter. with the wider lens the focussing distance will be less, with the longer lens more.
Thanks for checking your books, Mr. Hughes, cool stuff!
I agree with you, but Leitz does not.
