Finder
When using an adapter, metering is done in aperture priority. It works well at all apertures. Manual exposure can also be used.
Thanks. So, when it says 35mm on a PEN lens, do they mean 35mm equivalent in half-frame format or a 35mm in 135 that would be 70mm on the PEN/M43rd?
thanks
That is correct. 2x factor due to the sensor size.
Gary
It is confusing, but I believe the labelled focal lengths are at full frame.Sorry, don't mean to be slow on the uptake, but if I understand you correctly you are saying that when a lens for the original PEN is labeled '35mm', that means that it has the field of view of a 35mm in fullframe format (x2).
So, the PEN 35mm really is a 17.5mm that due to the 'crop factor (x2)' of the half frame format has a FOV of a 35mm in FF.
It's not so much an issue of how fast the AF is, but that AF is not really the right tool for street photography.
Scale or zone focusing is infinitely faster than any AF system out there and you don't need to center the subject to get focus. With AF you need to focus, recompose and then hit the shutter release. With scale focusing you compose and shoot. Much, much faster.
Harry, maybe you don't think AF is not the right tool for you, but I don't have any problems street shooting with the GF1's autofocus at all. I don't even think about it. I press the shutter and it takes the image whether the subject is centered or not. I even have it set to face recognition. What works for me might not work for you, and I have no problems whatsoever.
Thanks.
Thanks.
The GF1 rocks so much I got rid of my M6 for it. 😀 (Not totally true, I sold it to a mate who uses it more than I do, but the GF1 still rocks.) One day I might be able to afford an adapter for the thing, right after I save up for a second batterie. Damn things are expensive!
I think the only thing that's better about EP-1 is how damn good it looks.
Otherwise GF1 all the way for me.
