Olympus OM-4
Range-rover
9:48 PM
Hi all,
I just got a Olympus OM-4 and wanted to know how is the
best way to get the advance lever removed, does that top cap
pop off or unscrew?
Thanks
Are you intending to remove the top cover to fix something? If so, I would advise against it. It is easy to damage/tear the circuit board under the top cover when removing it (or replacing it) unless you really know what you are doing. If you damage/tear the circuit board, you will be left with a nice looking paperweight, as no replacement boards are available.
