markus_h_photography
Which version of the Zuiko 50/1.8?
Umm. It has MC on the front. Not "made in japan", just "japan". Whatever version that is?
I think version 2 ... I can't remember if there were three versions or four. Hmmm... I think four.
Yes, there is a difference with respect to both sharpness and bokeh. Zuiko-geekery has no bounds. 😀
First version silver nose (F.Zuiko) had harsher bokeh and was not as sharp at wider apertures. All aspects improved with each iteration, but I have a soft spot for the original release - the slight softness was charming. Neither of these shots show that. I vote for #2 as the Zuiko because of the bokeh.
A long, long time ago I used to think that F Zuiko was the name of the designer, then I wondered why his or her brother or sister D Zuiko designed some of the lenses. Then someone told me: that was long before the internet...
Regards, David
PS In pre-internet what they told you was usually true, unlike nowadays.
I'm not sure that is authoritative - it appears to be a list of lenses with serial numbers and observations by owners. I'm not disputing it, but when I see SC listed and the coating characteristics having more than one colour (e.g., "purple, yellow") I have doubts.There is a list of coatings for many lens and their serial number.
Some early 50/1.8 are referred as SC: http://olympus.dementix.org/Hardware/misc/lensCoatings.txt
I'm looking at a Zuiko 28mm f/2.0, but am wondering what the difference between silvernose and 'normal' (eg. blacknose) is in terms of glass or build. Is it just a cosmetic difference? I would prefer a black nose, but I've found a seller that has a reasonably priced copy of the silvernose.
In the last months I'm using my X-Pro 1 and some lenses. And there are some of my beloved OM lenses. 🙂
Here you have some photos:
Both with the Zuiko G 50mm 1.4.
