I tried this project several years ago. I started with an M6 and a Summicron 50. Unfortunately the M6 died in the 3rd month. I tried to continue it with another camera but I just could not revive the same resolve I had at the beginning. I did get the M6 repaired but that took about 2 months and though I did use it some more it was never exclusive after that.
If you review the guidelines posted by Mike Johnston, as I remember them, this is actually much more than just shooting one camera with one lens for one year. He suggests that you stay with a single black and white film and shoot two or more rolls every week. You are supposed to contact print each roll as you go along and use those contact prints to begin to choose some negatives to print. From time to time you need to make at least one good print and post it where you can see it. Mike was pretty insistent that if you did this for an entire year you would end up a far better photographer then when you started.
Anyway, I am always game to try doing something that will improve my technique and my skill so...here goes nothing. I am going to load up my MA with some Arista EDU Ultra 400 or Kodak TMAX 100, and start this on July 1. I'm still not certain which lens I will choose to work with. I am inclined to work with a 50mm lens but I really should take advantage of this to gain some real work experience with a wider lens. Maybe I'll select my Voigtlander Color Skopar 35 instead. Whatever I start with I should certainly be pretty familiar with it by the end of the year.
We'll see how it goes. I will try to post my thoughts and some pictures here at least one each week. Maybe I'll post some contact sheets from time to time and some of you can give me some pointers. Obviously this will also involve some developing and printing as well so that may stall things occasionally since I may not get each roll developed right away. I will try hard to keep up since I think that consistency is part of the learning process. It is hard to continually improve unless you are regularly exercising your skills. I will certainly do analogue contact sheets since those are not too tough, but I will scan and digitally print since my enlarger is not set up right now. But as soon as I can I will try to rectify that situation so I can also try rehabilitating my printing skills as well.
July 1 is right around the corner so I had better get cracking. I actually have several other cameras with film still in them so I need to try and finish them off before the end of this month. Not many days left to do that.
