Opinions on the Fed 2 in the link.....
The Fed 2 is a great shooter and dependable . The seller has been recommended to me before by an experienced collector friend.
I love the paint job on this one but for an everyday user I`d be afraid it will be very prone to chipping even with normal use. Unless the paint process is powder coat / oven cured it probably won`t last.
John
To each his own. I prefer the standard looking Fed 2
It's the best looking FSU camera out there, IMHO. In any color.
A clean one does in fact leave little to be desired. The size is really nice with everything proportioned so beautifully.
The one I had was so darn smooth and pic`s from it just grand.
I regret selling it but thankfully at the present time they are abundant.
John
I like the Fed 3a better than the Fed 2 for appearances, but the Fed 2 is a nice-looking camera.
This camera is pretty fun-looking but I like the worn patina of my plain black (or dark grey I suppose) Fed 2b.
The cameras are cheap enough - buy this one and a normal one for comparison purposes.
The wider rangefinder base of the Fed 2 will make it easier to shoot correctly and in focus. Just needed to add that thought.
Hello
My experience with that seller was positive.
He usually has a lot of painted cameras, sometimes with very imaginative colours and the paint-job seems nice in the photos. However, I am not sure of its quality and if it stands a daily use...
My own FED-2 is already lacking some paint, but I like it that way
Cheers
Joao
My single trade with that user was ok. The take-up spool modification seen in the link (swapped for the one from a Fed 3) is actually convenient, but the winding knob was very much improved when the design changed to the "mushroom" shaped one. The newer versions of the Fed-2 will also have the modern shutter speed progression and a modified shoe. The version on your link has the very low set accessory-shoe which can be a problem for some viewfinders etc.
There are plenty of these things around so I'd look for a later model and not worry about the paint-job. In fact, this is exactly what I did, and I can therefore confirm that the basic body size of the Fed-2 is the same as my M3 !
The seller "blyatnikov" often has cleaned up Fed-2, including black painted ones and that is the seller I used for my one, based on availability (mostly) and previous successful buys.
I can second this recommendation for blyatnikov. I've had multiple transactions and have been quite pleased--ships fast, packages well, and, of course, great product. What you see in his great photos is exactly what you'll be getting.
- Blake
Thanks for all the responses Gents
Think I will go for a regular flavoured Fed 2.....even if black and red is my favourite colour combo 😉
Do be careful with a camera like this. In many cases they repaint them
because of heavy, heavy use. Check the pivot holes in the shutter cage,
especially on the sprocket side.
