Darthfeeble
But you can call me Steve
I am sending mine back, We're not sure on the other, I had hoped for some insight to other post processing info. I know the Phase One program is supposed to be good. A little expensive.
Got my wife an X-T2 and liked what I saw so I bought a used X Pro2. We both went on an outdoor trip and I find that I am unhappy with the image quality in my Pro2. Very noisey particularly in the sky and the the mushy foliage blur that was such an issue with the first Xtrans sensor. Even the T2 has it. Both processed in Lightroom. Thoughts? Suggestions?
I confess to pixel peeping. One thing that surprised me is the Classic Chrome jpeg setting. I could see myself giving up RAW altogether. I won't though. Obviously my expectations were a bit unreasonable. All that said, my trusty X100 offers the cleanest files of any camera have owned. I can get shots at ISO 6400 that while noise is present, it is very manageable.
One point you made is to have the DR at 100%, does increasing that create some of my problem? I believe on that day I had it on the Auto setting and I was shooting at some pretty small apertures, thus it might have been more.
The OP seemed a little surprised that the Fuji did fine on the runway and backstage, even suggesting that he was taking a risk using it rather that his usual Canon gear. I don't see any reason why the Fuji, and a half a dozen other cameras, wouldn't do fine. What's with all the drama?
I understand going with what you are familiar with, but that goes to your familiarity with the gear, not its inherent capabilities. What specifically is it about the Fuji cameras that led you to the expectation that the Fuji cameras wouldn't handle the assignment nearly as well as your Canon gear?I've owned the X-Pro 1, X-T1, XE-2, and would not have expected any of those cameras to handle these conditions nearly as well. Just in my experience.
Makes you wonder how photographers were able to cover runway/backstage back in the film days.In the case of the X-T1, X-Pro 1 (lol) and X-E2, neither had buffers big or fast-clearing enough to handle rapid fire bursts of RAW files the way I needed them to. High ISO performance wasn't quite there either. The tracking AF on all three cameras was not bad (most notably the X-T1), but they were not as fast as the X-Pro 2's, or any number of Canon DSLRs. The responsiveness the older X-cameras and AF accuracy in low light was also not quite fast enough for me either - Canon performed just a little better before the X-Pro 2.
Again, many thanks for all the help here. What a great forum! If I understand the whole in camera adjustment thing, the DR setting should only affect the jpeg. My isssue was with the RAW output. None the less, I shoot a third of a stop under most of the time and sometimes even more. I'm trying shooting at 0 under to see what goes. The other compensation is to use the brush tool to reduce noise where it is most visible and as suggested, no sharpening. That has had the most affect toward improving my opinion of the image quality. The one factor that was most influential for buying the camera was the increased detail. I rather blindly continued the same workflow as the XPro1 and it's apparent that was a mistake.
This is NOT a critique of the previous X-Cameras, which I would expect to be more than good enough for most. Hell they're more than good enough for me 95% of the time! But the older cameras weren't quite enough for my needs under demanding conditions, like fashion week. They were 'close' but not quite there.
No - the DR expansion modes very much affect RAW files.
What's the easiest way to make a noisy file? Underexpose it, which is what the DR modes do
The largest amount of DR is available at base ISO
You'll get a cleaner image shooting @ iso200 and exposing for critical highlights and doing the shadow recovery yourself in post, than you will using DR400 and throwing away data before you even take the RAF from th SD card
I agree, I've used the XP1 at London Fashion Week before (a mix of Front of House/Backstage work) and while I could get some great images out of it I always felt that I had to finesse things a little more compared to my 5DIII/D800E. Some images in the link below:
http://www.lloydramos.com/foh/
http://www.lloydramos.com/pringlescotland/
http://www.lloydramos.com/katie-eary-aw14/
