peterm1
akptc said:Ah, yes, I forgot to mention that I like the "Dynamic" color setting 🙂.
Well, my "Pentax K-Olympus (3/4) Adapter" from Fotodiox has arrived. I mounted it on the L1, then mounted a Pentax AF lens (the 50-200 D lens) and - nothing. Can't see anything on the LCD or thru the viewfinder (lens cap removed). Do I need to crack open the Manual 😱 to figure this out or is there a simple answer to this? Thanks a bunch.
My guess is that your problem is that you need to manually open up the lens diaphragm. Could this AF lens automatically default to the smallest aperture? I do not know the Pentax AF lenses so cannot say. If this lens does not have a manual aperture setting (i.e. if it is all controlled thru the Pentax AF body) you may find that it will not work on this camera due to the need to manually set the aperture via a control ring. If your lens does not have on then this would be a problem.
There is one other thing when using manual lenses. In the settings menu (custom settings? - cant recall) you need to change the default setting that came with the camera to prevent its shutter firing when a lens is not mounted. As a manual focus lens has no chip, the camera behaves as if there is no lens and refuses to fire the shutter. This is a simple setting change that mystified me till I woke up to what the problem was.
