Gzisis89
Hey there, im also a pentax fan and used for many years a pentax mx and a full range of lenses that i still have. The problem is my eyesight since i cant see the whole viewfinder on the mx to focus acurate. Which of the film pentaxes has the best glasses friendly viewfinder ?
Zuiko-logist
the P50 has a large bright finder.
Cascadilla
The LX has a couple of options: a standard prism with a wider diopter adjustment range ( FA1-W) and a system finder base with a revolving low magnification finder that mounts on it for lots of eye relief and the ability to use it looking down at the camera as well as at eye level. This does add considerable size and weight. These accessories will be a bit hard to find now but they are out there. If you're lucky the FA1-W will have enough diopter correction to use without glasses and still see clearly, and since you can see the f/stop and shutter speed in the finder you can set controls at eye level. For any of the other Pentax K mount cameras that I am familiar with, there were correction diopters made that slide over the eyepiece in a rectangular frame. If you have severe astigmatism you might be able to adapt one of these. The downside of the high magnification finder of the MX was always the difficulty of using it with glasses. The LX with standard prism is a bit more friendly for glasses than the MX, as well as being quieter and more easily hand holdable at slow shutter speeds due to better mirror damping. It is bigger and heavier, if that makes a difference.
Zuiko-logist
I do love the Max finder - it is like widescreen cinema.
titrisol
Bottom Feeder
nickthetasmaniac
gzisis69
I just sent my pentax mx to get repaired since it started having problems and the lightmeter wasnt working. I am looking for a new 28mm lens to use it for street photography since i lost my smc 28 2.8 when i moved out and i cant seem to find it. Should i get the same lens or is there any better from pentax at almost the same size ? Since i almost always zone focus a little bigger focus distance would be welcome.
rx7photog
The lens reviews over on pentax forums dot com might be helpful. Read, especially, the reviews of the K, M, and A versions of the 28mm f/2 and f/2.8 lenses used on film cameras.... Should i get the same lens or is there any better from pentax at almost the same size ? ...
rx7photog
Disappointed_Horse
Don't rule out the 28mm f/3.5 lenses, either. It was made in versions from the Super Takumar series to K-mount versions in the K and M series. The optical formula seems to have changed in nearly every version, starting with 7 elements in 6 groups in the original Super Takumar with 58mm filter size, to 7/7 in the later Super Takumar and S-M-C Takumar with 49mm filter thread, to 8/7 in the K-series, and to 6/6 in the M-series.
I have the S-M-C Takumar version and I find it excellent.
titrisol
Bottom Feeder
I have both the M and the A 28/2.8 and the A seems to perform better wide openI just sent my pentax mx to get repaired since it started having problems and the lightmeter wasnt working. I am looking for a new 28mm lens to use it for street photography since i lost my smc 28 2.8 when i moved out and i cant seem to find it. Should i get the same lens or is there any better from pentax at almost the same size ? Since i almost always zone focus a little bigger focus distance would be welcome.
It might be a result of variation between examples but if I had to chose I'd get another A
agentlossing
The mention of Pentax Forums lens reviews is a great one, they are a fantastic resource. I have looked into this a little as well, since the M 28mm 2.8 I briefly owned really didn't encourage me on APS-C or FF K-1. Very soft outside of complete center. Consensus seems to be that the K series (or just SMC) 28mm f3.5 is really good, but it's a little larger and heavier.I just sent my pentax mx to get repaired since it started having problems and the lightmeter wasnt working. I am looking for a new 28mm lens to use it for street photography since i lost my smc 28 2.8 when i moved out and i cant seem to find it. Should i get the same lens or is there any better from pentax at almost the same size ? Since i almost always zone focus a little bigger focus distance would be welcome.
Then, if you have funds for a more expensive lens, the FA 31mm f1.8 Limited is a really superb lens. It's not super light, but, for what it is, it's fairly small.
titrisol
Bottom Feeder
I found a discussion from a while ago in PentaxForums Best 28mm lens for K-Mount? - PentaxForums.com (I only had the 28/2.8 M at the time)
It seems a Tamron 28 and a Vivitar and Rikennon are also highly regarded
gzisis69
I decided to give the 28mm smc m 3.5 a try since its small, has a relative long focus range between 1,5m infinity and 0,7m so i can play a lot with the 3 distances. Ill come back with results but i dont know when exactly
gzisis69
Where would you suggest to send my pentax mx with the new lens for repair- lube so that i can get the best experience of them both ? I live in Germany
Disappointed_Horse
agentlossing
Ricoh is a very healthy company right now, sounds like. I'm really happy about that since they make cameras I own and enjoy, and I think they do things in a less bloated and cumbersome way than many of the traditional camera companies have in recent(ish) history.
bjolester
bjolester
Zuiko-logist
Another beautiful shot. I would never have guessed this was at 300mm (effectively 450mm).
bjolester
Thank you😄Another beautiful shot. I would never have guessed this was at 300mm (effectively 450mm).
Oops... This was shot with the HD Pentax-DA 15/4 (I have edited my post).
