Calzone
Gear Whore #1
Agree the best thing that happened to me was when a friend pushed me to get into printing. I think it improves your photography in just about every direction, and like you, I like printing as big as I can... at home.
Love seeing someone using Piezography. I've read up on, thought about it, but couldn't
pull the trigger. Upgraded from a Canon Pro 100 that basically I bought for the price of the ink... to an Epson P800 which is very nice. My plan is to stick with the OEM inks while the warranty remains in effect... and after that look to Cone's stuff and the MSI (MIS?) group that distributes both B&W and color for him. They're still working out the P800, but it'll probably happen this year (so they tell me in emails). I've corresponded with Paul Roark who's also into custom ink mixes. We don't have Leica's, but Sony and he's done the Kolarivision mod for Astrophotography to pick up red sensitivity rather than go the Monochrom route. I'm undecided at this point as that's probably a year or more out for me. Yet I've thought and continue to think about the latter as Monochrom's are coming down in price (used). Curious which of the MM's you're running? M9-M or the current model? Also curious whether you've used the MSI/MIS (whichever it is) for color, too. I'm using Imageprint rather than the Quadrip at the moment and while expensive, it does a VERY nice job. Finding Matte papers ain't bad and often just right for B&W, but color is more of a Luster or Satin finish.
There should really be a forum here for printing!!!! that isn't a Yahoo group. "Just sayin'".
Roscoe,
Thanks for joining this thread. I think printing makes one a complete photographer, and in this manner who would not want to be like Eugene Smith and be both a remarkable shooter as well as printer. I likely will never be of Gene's stature, but I hope to emulate him as my role model.
I was an early adopter of the Monochrom. I had to wait 5 months for delivery, many of my friends thought I was nutz because I was a B&W film die-hard, but Leica kinda made my dream camera. So now my 4 year old Monochrom is at Leica N.J. getting a sensor replacement, and I expect 4 more years of trouble free service after getting an overhauled camera back.
So here is a secrete that I have published multiple times on this forum. I did a controled experiment comparing a B&W 2X yellow filter against a Heliopan 2X yellow contrast filter. The Heliopan is noticably lighter even off the camera, so I was expecting a bit less contrast, but I was blown away by the noticable dramatic difference in the histogram.
Somehow I got rid of the clipping, the midrange became prominent, and the histogram covered ten-zones denoting perfect exposure. Somehow the Heliopan filter hit the sweet spot of the MM sensor. I explored further and compared Heliopan 2X yellow filters: one was marked "Digital;" and the other wasn't. The Digital marked filter had something special going on, and I would later learn that Heliopan filters marked "Digital" have additional UV and IR filtering to eliminate those lumanance signals.
My friend Willie would correct me if I call the unwanted signals noise, but this filtered out light only adds to dilute the visual information, and in my context I call it noise. Anyways the "Digital" 2X yellow filter has a few effects: it removes unwanted non visual signal that adds to clipping; it allows one to maximize exposure (shooting exposure more to the right) for cleaner files with a higher signal-to-noise-ratio; and it creates files that only require minor tweaking so printing big without digital artifact is pretty easy.
Ultimately I would want a M-246 as well as my MM, but if I could only have one it would be the MM warts and all. The M-246 is a much more advanced camera with better shadow detail and softer roll-off in the highlights, then you have great high ISO performance, and a more updated camera, but the rather primative CCD has the huge big midrange that offers an organic midrange that resembles medium and at times large format.
So basically if you want long tonal range for that larger format film look than the MM is the better camera, but the M-246 is a better camera in just about every other way. Boosting the mids to get a similar effect in post processing might be easy to do, but realize this boosting of mids to attain the levels to resemble larger formats I believe will add digital artifacts and hurt IQ. My experience from heavy use of sliders and curves in LR5 suggest a more organic midrange is easier using the original Monochrom with Heliopan filters, but I am unsure the M-246 will respond with filters in the same way or to the same extent.
But here is a spin: the 18MP CCD sensor utilizes a 14 bit processor so 18MPx14-bit= 252MB files, but the M-246 although has a 24MP CMOS sensor is only 12-bit, so 24MPx12-bit=288MB. The end result is that the files from the M-246 are only marginally bigger.
Since I own a Leica SL, I have to say that it is big deal that the SL has a processor derived from the Leica "S" medium format camera, because due to the more advanced processor the SL has the processing speed to go 14-bit, so 24MPx14-bit=files that are 336 MB. So if you compare a M-240 to a SL you really can't.
The new M-10 is 14-bit BTW and now that Leica "S" procesor has trickled down into a color M digital. Wow. Know that the M-10 is streamlined when compared to the SL which has AF, Matrix metering and video, but the M has a rangefinder and its compact size and weight are its most obvios advantages.
So the reason I mention the M-10 and SL is I predict that a SLM will come out perhaps this fall at PhotoPlusExpo, anyways that is my wish, and it will likely get staggered till 2018 that a M10M might come out.
For me since I already own and shoot a SL a SLM would suit me just fine since I love "R" glass, already pre-paid for a 50 Lux-SL, and am number 5 on a dealer's waiting list.
Cal
