M
Magus
Guest
Post deleted by posters request
richard_l said:Heed Magus' post concerning the Summaron and the Summicron-C.
Richard
Didier said:Take the fastest. Speed matters, as you say yourself. The CV 40 is a great lens, sharp, contrasty, compact. It's true it's bokeh is not great in certain situations, especially distant highlights in the dark. There's a thread about that here, with a lot of pictures, some from me.
The advantage of it's speed and compactness weighs much more than the bokeh issue which I consider as minor. These bokeh situations are rather rare, and if they once happen, just stop down to 2 or 2.8 and gone is the "bad" effect. I used it as main lens the past 2 years, on a M6. It became a bit "too long" since i use a R-D1s mostly, but is still sticked on the M6.
One can't go wrong with that lens, and I'd prefer it over the Ultron in any case.
Didier
richard_l said:Heed ('Give consideration or attention to') [M. Webster's Collegiate Dictionary] what Magus posted.
You are correct about the lenses, although the issue about the resolution and contrast of the Summaron at the outer fringes of the field of view is not necessarily a crucial consideration. In most of my shots the deterioration away from the center is not noticeable.
Richard
Oh Two said:..... Summarons don't give that 'wide' look (buildings leaning backwards, eliptical heads, or big noses). The image is naturally flat. Compare that with CVs...
ferider said:I always find it interesting that there are very few example shots
available for the 35/1.7, wide open. On the other hand, users
swear by the OOF behavior of the Ultron's bigger brothers, the 28/1.9
and 35 Nokton.
IMO, the 35/1.7 OOF behavior is really great, just as good as the 28/1.9.
For sure, better than the Summicron 35/2, the Canon 35/2,
the Summicron 40/2 and certainly the Nokton 40/1.4. No double
lines, no donuts, even against light sources at night. Also, the 35/1.7
is very sharp and has nice contrast (not too much, which I like).
It's only issue might be ergonomics (it is quite large).
It is relatively cheap, comes with hood, and has good resale value,
so you can always try ...
35 and 42 (the 40 Nokton's effective FL) are not as close together as
it seems. 20% to be exact, 42 is in the middle of 35 and 50.
24/35/50 on the other hand is a great combo (area factor two
between all three lenses).
Roland.
Roel said:Oh two mentioned something nobody reacted upon. I have seen no examples of 'wide' look on pictures by CVs yet. Can any of the CV users comment on this remark? Or perhaps somebody could show some examples.
Tom A said:Over the decades I have used most of the 35's available for M's...
