Blooze
I finally picked up my new computer build last weekend and plugged in my Plustek for the first time since I bought it in November.
I played with it for most of an evening with one negative and finally seemed to hit on something that worked OK. I was wondering if someone might have a better starting workflow for me than the following for B&W negatives with Silverfast SE+ 8, other than buying new software for now?
I chose negative, color 48-24bit, Photograph 1 at 3200 ppi, Adobe RGB, Negafix Delta 100, all sharpening etc... off, did the prescan and adjusted the frame then the histogram to grab the whole spectrum 0-255 (which it was showing) and the middle tone at 0. I then scanned as a tiff, imported in CS4, and chose the green channel which seemed to look the best before applying a slight curve and some dust removal/dodge/burn/slight sharpen/convert to sRGB. I tried desaturate instead of just the green channel and it was OK, but the contrast was a little higher.
Here's the first scan downsized for the web.
