Poly Pan F iso 50 film
Polypan @ 50 iso. Rodinal 1:200 for 120 minutes. The base of the Polypan is a bit of a dustmagnet and you spend a bit of time spotting (thanks Lightroom!).
Nikon F, Micro Nikkor 55mm f3.5
The Ur Menu - rivals even a modern digital camera in complexity. By the time I have figured ut the season,time etc - t is usually to dark to shoot. The Mercury Univex II is fun though - 72-75 shots per roll 18x24 mm sized. The camera is prone to have frozen helicoils as the thread is running alloy to alloy.
not sure if this is same reason why ppf may have spots
With Shanghai you have to be extra careful to cut the sticky tape (attaching film to paper backing) off when loading the film. It seems to deteriorate in the bath and land on emulsion as the spots.
Polypan F, 100 ISO, 15ml Ilford DDX + 650ml water, 30 mins stand development at 30 deg C. 1800DPI scan. The negs are a little thin for darkroom printing but scan well.
ppf_ddx on Flickr
The next two photos show the drastic light fall off for anything in shade
ppf_ddx2 on Flickr
ppf_ddx3 on Flickr
while the bright stuff holds together pretty good.
ppf_ddx4 on Flickr
Maybe it's the way I photoshop the pics. Here's a raw scan for anyone who wants to try.
polypanf_rawscan on Flickr
Sorry to dig this old post out again.
I have been doing the same approach as you do (scanning the negative in raw and then converting into B&W later in Photoshop), but I am encountering problem with tuning the contrast.
I used to put a straight away invert layer, into a level adjustment layer for tuning the level of each RBG channel (I just drag the sliders to the ends of the histograms), and finally a black & white layer. In this way I usually have a greyish sort of layer over the photo.
I recently try a different method: invert layer > level adjustment layer to drag sliders of each channel > do a calculation combining the red and blue channel with soft light mixing in order to convert to a new black & white channel. In this way I usually have a high-key image.
Apology in advance if I am a bit off topic, I know I should be discussing the film here, not the Photoshop techniques. As you posted the raw scan, so I had a play around with it. It's interesting to see either of my way can't get the result of the final photo you got (which I like the taste of it). How do you get the contrast just right? Do you mind to share with us your workflow of processing the raw scans into B&W photos and some techniques used in Photoshop?
Jon
Jon
Hi. That sounds complicated. All I did in Photoshop was:
Crop to remove any overscan of the negative area (optional)
Invert (Ctrl-I)
Desaturate (Shift-Ctrl-U)
then either
Levels (Ctrl-L followed by Alt-A for auto)
or
Curves (Ctrl-M followed by Alt-A)
Hope that helps.
BUMP.
Anybody got something more to show from PPF, maybe in Rodinal?
Best used in flat or in contrasty light, low or high contrast lenses? How does this film scan?
Just developed my first PPF film (thanks, Henrik!) and it looks real good. I gave it a cold treatment of Rodinal 1:100 at 16ºC, to keep grain down.
No time to scan now, off to bed. But I'll be on it tomorrow once I return from a little paid photo gig :cool: and post some shots here when I can!
I used this film exclusively through past summer and haven't finished 90m bulk yet.
Started with D-76, switched to xTol, where it seems to be better.
Every frame has two noticeable spots after developing, at the same places. Each of two is the cluster of black dots.
If it gets on the face, very difficult to mask it.
Not so good with details in white, bright after scan. But it is recoverable in digital PP.
Haven't tried wet prints from negs. Printed digitally at Costco lab on weekend some family portraits. Good results.
Pool by Ko.Fe., on Flickr
Untitled by Ko.Fe., on Flickr
Sky, reflection and underwater. by Ko.Fe., on Flickr
Me. Almost. by Ko.Fe., on Flickr
Spots in the same place on every frame. . . . are you sure you don't have some holes in your shutter? That sounds like a camera-specific problem, not a manufacturing one.
Does anyone know where to get Polypan these days? I´m running low and when looking for new rolls I couldn´t find any!
Sorry, don't know, last month die camera-boerse still had some stock, but not looking to good right now. If you get desperate pm me.
Maybe it's your bulk-loader acting up, sound strange to have exactly 1 frame separation between such anomalies.
No, it is in use for many other rolls without this problem. It is just dirt cheap film. And I have another 90 m of it. :)
