j.scooter
I just did the update and noticed that the frame lines move when you focus ala Contax G.
tres Cool 🙂
tres Cool 🙂
tres Cool 🙂
This worked with the previous FW as well, unless I'm missing something.
Probably not missing anything. It entirely possible that I hadn't noticed it until now.😀
what will people lament now?
Now that the focusing speed seems 1.5x as fast (actually, it seems a bit faster), and you can go from 1m to ∞ in 1/4 turn, what will people lament now? The new 3x has sufficient contrast that it almost focus-peaks.
Dante
I also noticed that files with adapted glass appeared underexposed. If there is one thing I know about my living room in the middle of the day the correct EV is 1/60 @ f:2.8 at ISO 400.
I didn't understand the comment about DR being set to 100? What should it be set to?
[I see that the manual (RTFM) states that higher DR numbers are for lower contrast scenes. Does this matter if you are shooting RAW? It seems like it shouldn't but what do I know?]
Mildly clueless. . .
Ben
Frame lines are not an issue.. U just need to know the trick.. It turns out that there are two settings for display brightness.
When u are not looking thru the ovf, q menu LCD brightness is for the LCD. after u set this to your liking, the ovf one can be set by placing your eye up to the vf and using the q menu again. The evf brightness follows the ovf in the past. Not sure if new fw changed this behavior (ovf/evf pairing)...
Gary
Overall, a very nice update. It feels like a different camera. AF is pretty snappy. I especially like that the scene doesn't lock up in EVF while focusing.
Manual focus is the biggest thing I'm happy with though. I actually got used to the stock XP1 MF (it's much better than the X100), but the speed of v.2 MF is really nice. Speaking of the X100... I hope they do release a v.2 FW for that as well.
One issue that I'm noticing though on the new FW though...
For those of you that shoot an XP1 with adapted glass (I usually use a CV 25mm Snapshot Skopar and occasionally a Jupiter 8), do the any of the auto settings (Aperture priority, anything with Auto ISO, etc.) seem a little under exposed to you? It seems like everything is under exposed by about 1 stop.
I usually have to overcome this by either:
1. Turning off Auto-ISO and setting the exposure comp +1 stop.
2. Shoot full manual aperture, time and ISO then and just "know" what the correct settings are (generally +1 over the meter)
... wondering if any of you guys are experiencing the same phenomenon.
-- EDIT --
I guess the camera wanting to underexpose on an auto setting only happens indoors or dimly lit areas. Changing the metering mode from Multi to either Spot or Average seems to calculates a more correct exposure. Outside in the daytime seems fine. I don't remember having to adjust for this before.
The inability to set a minimum shutter speed when using Auto ISO;
The framelines which are claimed to be too tight (but in reality are similar in coverage to Leica M framelines);
The lack of RAW support from Apple, and the lack of competent RAW support from Adobe;
The thickness of the sensor cover glass, which accentuates corner smearing with some wide angle lenses;
The perceived need for full frame;
And the fact that some people might call it a rangefinder.
(Only two of these issues actually bother me.)
Why is it that so many of these cameras these days aren't reaching their potential until a firmware upgrade or two?
What is it in their development/design that puts this part of the device's firmware so far behind it's hardware?
I'm genuinely curious because to me it seems akin to a car manufacurer giving you car with four speeds in a five speed transmission then fitting the fifth at the first service because it wasn't quite ready at sale. 😛
