price check
Found the same lens...and it's local to you. The BIN is a bit high-most go for 225 to 275 US$. The starting bid is good and maybe local p/u is a possibility.
"must be nuts..." Only a squirrel would care.
local pick up is a go.
with no bids so far i think i'll try for it.
back alley said:
what's the going rate on a minolta 90/4 m mount lens in good shape?
i did a completed search on ebay and came up empty.
thanks.
joe
Hi Joe,
If possible try to find a Minolta 90mm F4 lens made for the CLE not the CL version. The CLE version is multicoated and is a slighty improved version of the Leica CL and Leitz-Minolta CL models. You can tell the difference by looking through the lens at a a light. The multicoated coated version will display several different colors. Also, the multicoated version will have the serial number on the bottom of the lens barrel. 🙂
Andy
