Brusby: "But if you look at white values in the borders, which are entirely possible to have in the print, there are none or at best very few in the prints. I would have been fired if I had turned in prints like that."
Is there a law that states that there must be pure white in a print? Have you ever seen a print of a photo in a book that contains pure white? Have you ever seen an etching that contains pure white? Have you ever seen a painting that contains pure white? Pure white does not exist at all. Pure white is an abstraction that occurs neither in nature nor in art. Even the sun is not white. Everyone can see that.
Maybe you mean unexposed white photo paper. That's enough in my example, around the photo you can see an unexposed edge. But why should there be unexposed white photo paper in a photo?
Erik.
All artwork is an abstraction that doesn't occur in nature. And pure white does occur in much artwork, particularly in b&w prints of many of the worlds greatest printers and many of your contemporaries.
In b&w printing pure white is only one of the many tones available to the printer. You have every right as an artist to chose not to use all the tones available to you and to have a shade of gray as the lightest value in your prints. My impression is that it gives the prints a dull, muddy appearance. I understand you see it differently.
When I look around me at things that exist in real space, I usually get the impression of very light areas that contain small areas of pure white -- things like specular highlights, some white paint or very light objects in sunlight, the lightest parts of some white snow, some areas in an outward facing window in sunlight, some backlit hair and much more. I think those things can best be represented by the whitest tones.
There is no reality in photo prints or other art work, there is only the impression or perception of reality we as artists choose to make. Using all the tools available to us, such as a full tonal range, helps make the job easier. To intentionally limit your range of tones seems counter productive to me.
p.s. And it's less about pure white than the range of tone which exist between the gray where your prints often stop and pure white. Those often delicate tones can and often do give a lightness and sparkle to prints.
