Calzone
Gear Whore #1
- Local time
- 10:18 AM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
So, can I use the Cone inks (?) in my 3880 and still print decent B&W and Color? I'm not quite clear what the difference is among all the choices.
Maggie,
Piezography is Jon Cone's B&W only systems. If you only print B&W this is the way to go. The darkest blacks. With K-7 you are printing with 7 shades of black and the inks are carbon base so they are not prone to fading. The resolution and fidelity I would say is realized in big prints, and with Piezography I bet any file would or could be printed bigger. I print 20x30 and still can nose-up into a print.
Jon Cone Color are encapsulated inks just like Epson OEM, but are about 1/10th the price per ml. Of course you have to buy refillable carts. The compatibility is so transparent that you could even use the Epson profiles with the Jon Cone inks, but of course the best results would be to use the canned profiles available that are optimized for Jon Cone's inks that are available from their free library.
What I have to do further research on is using the new blacker black developed for Piezography Pro (the B&W inkset) with the color inkset. Not sure these profiles are free. I can tell you that the black is blacker than anything else I have seen except perhaps some blacks made by alternative process. This new High Density Black is a great thing.
For B&W and color printing the Jon Cone archival pigment inks is the way to go because of the cost savings. Also know that the 3880 is a printer that has great durability, and long print head life.
Cal
