Producing slides from BW400CN?
rckt3
9:17 AM
I recently heard that BW400CN can be developed to slides, and the person was impressed with the them but did not know the exposure or development process needed to accomplish this.
I can find information on Kodak's site for using TMAX 100 and TPan to produce B&W slides.
I would like to try this, but I cannot find the exposure adjustments, nor the development process to produce BW400CN slides.
If you use a slide copier to re-photograph your negatives at 1:1 magnification, the results will be positives (B&W slides) of the negatives. How good they look depends on your exposures and the film you use. I would think that B&W C-41 film might inherently be a bit thin due to the lack of silver in the emulsion but who knows? It's wortha try.
I found the following:
Cross processing C41 film through the E6 processor is possible - we recommend that your film is pushed two stops when taking your photos and also pushing the film by two stops when processing your C41 film.
I will experiment this week-end to see what this looks like as I just picked up a pro pack of 220 BW400CN. Gives me 8 shots a roll to play with 🙂
following up
following up
I would be interested to see you let this thread know the results of your experiment.
Jan
I know this is possible with Ilford XP2, but that stuff has no orange base color.
Go to www.dr5.com. That's all he does, make positives out of just about any B&W film. I had him do a couple of rolls of Tech Pan 120 and it was superb. I left a on the big light box at the store that I used tp work at one day and we sold more Tech Pan that day than we had in the year previous.
Well, the first set of the film is underexposed, and I might be able to make a print out of a couple. This weekend I plan to do more formal film speed + E6 push testing to figure this out better.
I also checked with a couple of local shops to see if they could do a set of film exposures with a calibrated light source and a step wedge but none of them will do it. One does it in house only 🙁 Need to make some more calls to out of state people to do this work, dang.
