Push it; push it real good.
neilsphoto said:
Did I read that right? You agitate once every 5 minutes? The other day you posted another pushed Rodinal shot. What speed was that shot and developed how long and agitated how often?
I'm a Rodinal fan but I've never used it for pushing.
Neil
Nope, you read wrong. I invert five times every five minutes.
The previous shot was at 3200, 30 minutes, same agitation.
This appears to be a speeded up variant of 'stand' developing. That accounts for the really excellent shadow detail in such a high iso rating. I'd heard about it as a technique but hadn't until now seen the results. Impressive!
Gene
Ok! You got me! I just loaded Tri-X in my G2 and set it to 1600. Let's see what I get until the weekend. I have some AM74 left which I will use 1:15 as one shot developer. There are two rolls Delta3200 left I intended to shoot at 1600 as well.
merciful said:
Tri-X at ISO _____? Nikkor 135mm f3.5, developed in Rodinal 1+50.
Care to take a shot at filling in the blank?
Nice picture. I couldn't even guess at the rating. I haven't pushed film in 30 years -- Just decided there wasn't anything that 400 ISO wouldn't handle--and if it wouldn't, I probably didn't need to shoot it anyway.
Gene
Thanks, Gene. There's a very significant difference in result between the same push in Rodinal and HC-110: there's much less shadow detail with HC-110.
Thanks very much.
I don't think there's one in a hundred exposures I could make if I had to use film rated at 400.
djon said:
How did you scan it? Is that close to full frame? Nice.
Funny thing is, most claim you can't push much with Rodinal 🙂
Thanks. Full-frame, scanned with a CoolScan 8000.
Hey Merciful... wonderful shot and very interesting processing results.
Yeah, what temperature? I have adored Rodinal for years. I am just diving back into photography, so have to reacclimate myself.
A "new" paradigm for developing b&w is less agitation, which is said to avoid grain clumping, and higher temps (up to 24C) to reduce wet time. I picked this up from http://www.mironchuk.com/HC-110.html and although it is written for HC-110 times, adapted it to Rodinal for APX 400 andit seemed to work well.
Cheers to you and others in Halifax.
Trius
Thanks very much.
I have never agitated much (with film, that is.) But I hadn't heard about the increased temperature stuff: I'll investigate.
That was at 70F.
Trius
Soo..
I'm lazy, and I have a Jobo and some Rodinal. Could I get similar look at this ISO via an extreme push with constant agitation? I could set it to spin slowly, but it would have to be continuous if i were to use the Jobo. Any recommendation for time? Also, I can regulate temperature so would going up/down do anything for me?
I have done lots of pushes in normal D76/Microphen but always done my standard 10sec agitation per 1minute. I have never gone to the extreme speed/time of this method.
Btw, I knew it was 12,800 because you mentioned you were going to do some experiments at that speed in a previous thread (the 35/1.8 one I think), for some odd reason this kind of things go straight into my mind and I can't forget them.
Some time ago we had a thread with a how a possible push with Diafine should be made (going more than once through the A&B baths), I think you could be our man for that experiment as well.
Pherdinand,
I have very good experiences with Calbe A49 (diluted 1+1; now also sold as Adox ATM49) for pushing films. You can mail-order it from www.fotoimpex.de (the best source for inexpensive darkroom supplies in Europe, IMHO).
You could also order their inexpensive, yet excellent A&P developing tanks!
Roman
Oh, and be careful with Rodinal at temperatures higher than 20°C/68°F - in my experience, grain gets reall much worse; when originally formulated, Rodinal was intended to be used at 18°C!
And yes, it is true, Rodinal _in regular use_ is not good for pushing (that is, low dilutions, regular inversion schemes) - but things are different when using it in high dilution with minimal/no agitation (so Stephen, no, rotation won't work - and is not a good agitation scheme for Rodinal anyway - if you are lazy, try 1+100 dilution and stand developmen - just make sure there's enough developer in the soup - AGfa recommends at least 10ml per film, which would give you 1 l of mixed developer at 1+100, but you can go slightly lower around7 ml per film should still be safe).
Roman
Roman
I'm using 6.25ml + 300ml.
looking at your 35mm results, i can already dream about using tri-x in 120 format pushed real hard, shooting nighttime with the super ikonta and the rolleiflex...oh boy, nice days to come...
Once there was a posting here about pushing 120 tri-x (i think) to iso 102.000-ish, where the backing paper was not thick enough and the frame numbers showed up on the neg...looked really cool...was it you who has done it?🙂
BTW, is the thread title a reference to that nineties rap song?🙂
