What kind of fix are you using?
Regardless, if you want to use that tongue of film you cut off, toss it in some fix and see how long it takes to clear, your answer is 2x that and you should be good to go.
I believe the Ammonium Thiosulfate fixes are the liquid ones and are pretty fast.
I prefer to use a hardener, and I believe most of the liquid fixes do not have one, so you might want to think about that. Folks may not want to use hardener with fiber papers, and may wish to leave it out.
Chemistry is still cheap enough to not have to push its life. Once the liquid fixes throw a sediment from siting around too long, toss them even if not used.
I pull the top off the tank 30 seconds after putting the fix in, never had a problem and it allows me to see if it is clearing evenly and quickly. If it is clearing slowly, I would put some fresher fix -- you can fix twice, or three times, no problem, I normally use two baths for paper.
Regards, John
