Questions about Nikon F100 and B/W
Pfreddee
7:16 PM
In the suburbs of Dillwyn, Virginia
I'm still learning about how to shoot B/W with my Nikon F100, and I wanted to get some tips or ideas about some approaches to try. I usually shoot in Matrix metering and Manual Mode, with a 50mm f/1.8 (the older AF-D model), hand-held. I was wondering if Center-weighted metering and Manual mode would be more appropriate as a routine, or use Spot metering and average the exposure based on several readings. I have had good results with Kodak Ektar 100 colour film shot in Aperture mode with Matrix metering, but I suspect that B/W film will react differently. Of course, I could be wrong, but I haven't shot enough B/W film in this camera to get a real feel for things.
Thank you to all who reply.
With best regards.
Pfreddee(Stephen)
I used F100's for a long time along with F5 & f4's. Use them in matrix and manual. Center weighted is ok too but matrix is much more sophisticated approach to exposure. Until you learn more about your camera and spot metering I wouldn't mess with spot. You can fool it much easier. B&W exposes just like color. When you expose a frame of color you're actually exposing three (or more) B&W layers on a single base of film. The. Olof couplers exist along with them but you're not actually exposing them. Only the B&W part of the film is sensitive to light.
The F100 is a really sweet camera. Very versatile.
Just load the film and set the camera on matrix and manual and have fun. The matrix meter is excellent. Matrix has the means to see things like bright sky and compensate or to see a light source in the frame and. Imps sate where the other modes do not. Matrix isn't foolproof but it's better than center weighted.
Whether using matrix or center-weighted or spot you should keep in mind that the camera, not you, is deciding where middle gray is -- when you point your spot at a specific part of the frame and the camera sets the exposure, say, to f/8 at 1/500th of a second, that area of the photograph at that exposure will be at the middle of the tonal range. As PKR points out, with b/w film, you want to cheat toward overexposure if you have shadows or dark areas twhere you wish to retain details. So -- you can use any of those settings effectively AFTER you learn how they work and what the results likely will be -- then you can work around their weak points. For now, just experiment -- oint the F100s spot at various parts of a potential image and note how much the exposure changes; and visualize what the image will look like if that specific spot is the middle of the range -- will the blacks be too dark, or the whites too bright? Figure out which is the correct exposure for what you want for that image. Then change over to matrix and see what exposure it selects. It's very good metering system and you'll see whether it picks "right" most of the time or not. Most of hte time, I suspect, it will. When it doesn't, figure out why, and learn to watch for those conditions so you can correct for the camera.
Read Ansel Adam's book "The Negative." You won't understand much of it. Keep working, studying, go back and read parts again. Repeat this for several years. You'll get really good.
I found when I was starting out a few years ago that as I learned I wanted to control my own exposure and learn from that process. I used meterless cameras with handheld meters or using Sunny 16 rules outdoors in daylight. Now I feel I know at least the basics very well, and I have no issues with Aperture priority autoexposure and other automation but I intuitively compensate for that system's prejudices.
