R3 Mot battery question
erinrules
4:12 AM
hello guys,i just took posession of a r3 mot.it isn't an m series but hopefully someone here might know the answer.the battery testing device doesn't appear to be functioning but i do have metering with the battery installed.is there another test to see if the unit is powered up?.i am still waiting for film to arrive.
thanks.
thanks for the input guys.i assumed the battery was dead when the test button showed nothing but fresh batteries changed nothing in this regard.the metering doesn't have an led but rather a slash like indicator,it no longer adjusts when i remove the batteries so hopefully that is a good sign as well as the shutter working.
Yea, you are probably good to go if the meter and shutter work regardless of what the battery test on the camera indicates.
Bob
