luketrash
Trying to find my range
My R3A started skipping frames back in about February and has not stopped. It happens with fairly regular occurance now.
What happens is when you wind to the next frame after taking a picture, it snaps and you have to wind it a second time to set the shutter.
I've been out of the fray of the RFF forums for a while, so I haven't seen anyone else talking about this before. Have any of you had this happen?
Also, if any of you have had this fixed, how much money did it cost?
It's originally a CameraQuest camera that I bought second hand (working.)
The other symptom is that I never use the speed winder I have for it because in that case, it has been known to overlap frames.
However, that issue existed prior to the frame jumping issue.
Thanks for any info! I'll check back in a while. I have been fairly out of it lately, so I may not see the thread for a bit.
