Vince Lupo
Whatever
Can someone tell me what the separation is between the pairs of images? Would the pair be the equivalent of a 24x36mm frame? Or is it wider?
It is wider than a single frame. You get 29 pairs on a 36 exposure roll; and there is little to no space between the images.
The problem with stereo today in 2020 is that hardly anyone is willing to “do it” like it was meant to be. That is, slide film correctly mounted and looked at through a hand held viewer. ...
In my wet plate days I used a 5x8 Camera. Now.....for cards, that’s the way to go. Contact print a wet plate neg and it has the required sharpness. BTW the OP needs to understand the transposition of images right to left, and having a bit less “info” on the left image.
Vince, you should get a Sputnik! A 120 stereo camera from the Soviet days. I think maybe you can just proof print them for a proper stereo card.
http://www.analogadvocates.com/page/sputnik
PF
You really need an Alignment Gauge Set for Mounting 3-D Slides; this will assist in making the pairs aligned properly.
A bubble level, shoe mounted or otherwise, is also very helpful in keeping the camera level. When the level is off, even just a bit, you'll have to rectify that in mounting making a tedious process that much more difficult.
