Rare: 50mm LTM Compur-Summicron + Compur-Summitar
raydm6
10:12 AM
North Central Massachusetts (USA)
I have never seen one of these and wonder why it was designed this way. Perhaps to be used a body minus a shutter? I'm not seeing a rear view but it says its a screw mount.
https://www.setadelstudios.com/colle...s-only-58-made
2_1c4b94be-16ff-43c4-a3a0-58128488aeb5_large.jpg?v=1652988165.jpg - Click image for larger version  Name:	2_1c4b94be-16ff-43c4-a3a0-58128488aeb5_large.jpg?v=1652988165.jpg Views:	0 Size:	58.7 KB ID:	4793412
Found this article with pictures. Crazy set-up (Compur-Summitar):
https://filmphotograph.com/summitar-...r-shutter-1950
It appears that this shutter-button adapter allows you to use either the internal body shutter, or use the lever to use the lens compur shutter which I believe allows flash-sync at either 1/100 or 1/200? I like the looks of the lens and the beveled/scalloped aperture-ring. A nice aesthetic.
A deeper explanation - from: https://lens-db.com/leitz-wetzlar-co...-50mm-f2-1954/
FTE.png - Click image for larger version  Name:	FTE.png Views:	0 Size:	152.7 KB ID:	4793417
And a PDF manual on how to use the lens: https://lens-db.com/wp-content/uploa...2/10/02138.pdf
Older thread with some background info:
Maybe the camera shutter is supposed to be on Bulb when this lens is used. If so, then the device would trip the camera shutter first, then trip the Compur shutter while the camera shutter is still open. Just a guess.
Yes, you either use the mechanical adapter/link, one version of which opens the camera shutter first, or you set the camera to B and open the camera shutter first then fire the lens shutter. It's pretty awkward.
