back alley
IMAGES
too bad the rd1 is such a lousy camera...cause it makes such nice images...and i like them...alot.
I am using the M9 in all manual so EV compensation is a no issue to me 😉
Here is why the M9 is superior to R-D1 in ergonomics :
- though the R-D1 has a ISO dial, it is difficult to change when you have big fingers + you can't read it at night. M9 and ISO button and a bit of practice mean you can change ISO without looking at screen. At night, obviously screen can help.
- the M9 shutter is more precise, the R-D1 you never really know when it will trigger.
- the M9 shutter is very silent, the cloing of the R-D1 could wake up dead people.
- menu system ... ever zoomed with the R-D1 to check focus on the bottom right corner ?
- speed dial on M9 has half stops, R-D1 full stops.
- framelines on M9 are brought up automatically, R-D1 you can be 10 minutes framing 28mm with 50mm lens on. Fun!
- continuous shooting ... I don't use it but let's do a speed contest.
- AWB, file size, etc ... yes there are dials but I'll am still faster through menu system on M9 than wheel + selector on R-D1
I have shot extensively with both camera and obviously thr M9 is not perfect. But overall ergonomics are way better than R-D1 once one gets used to it. R-D1 has got nice dials, but fails in many other accounts.
The R-D1 was my first digital rangefinder and used it extensively for a year.Well I personally don't like having to set the shutter speed, so i guess EV compensation is more suited to my way of taking pictures in A mode 🙂.
The only occasion where setting the ISO becomes a pain is, as you suggest 'you can't see it'. I guess it's very hard to grasp that the maximum iso is where the limit of the turning wheel is. A camera you can use your eyes closed! And I have 'Fat fingers' and I managed fine with the RD1 to move it.
Regarding the shutter, I never had a single problem with the RD1 shutter. No idea what you are on about here. Perhaps the camera went into sleep mode or you had a dodgy model. Having said that this is not what I would call ergonomics.
Regarding the shutter noise: The RD1 is loud yep. I agree. This is inconvenient sometimes.
The menu system on the RD1 is as bad as it gets. The whole point of the RD1 is that you *don't actually need it!!!* I have not used a M8 or M9 apart from testing it in stores and I wouldnt give the menu system any awards either, but it is seems only marginally better than the RD1.
Regarding the framelines, the little selector on top is a great way to select lens. What's wrong with it.
Regarding WB..etc I shot in raw so I couldnt not care less.
So, about swapping batteries and memory cards no the M9, how is this done again ? 🙂
PS. Did you actually use your RD1 or was it sitting on the shelf?
