triplefinger
my converted DNG files WORK!!!!
so excited.
so excited.
How did you convert your files (what settings in Adobe DNG Converter)?triplefinger said:my converted DNG files WORK!!!!
so excited.
kepstein said:How did you convert your files (what settings in Adobe DNG Converter)?
Thanks,
Ken
triplefinger said:here's what works for me.
Doing a little testing and found importing my Aperture 1.5 library into Aperture 2 reveals the OLD problem of RD-1 files which have been converted to DNG, NOT displaying and showing the "unsupported image format"
The same file freshly imported into AP2 works just fine.
I guess this means losing some previous adjustments. Fortunately, I still have 1.5 should I need to go back.
Just thought this was interesting.
Mike
Thanks, that worked. I thought I was going crazy. I just re-import the pics as you suggested. Then lift and stamp the adjustments to each picture. Long process but a lot faster than having to modify each. Afterwords, just sort by import date and delete out the older Raws. 🙂
Now I can shoot raw again if I needed. Prior to this, I rarely shoot raw. But will still keep the raw pics to a minimum and will use it only on critical or travel stuff.
Here's a link of some random pics taken with the R-D1. I can't remember but I think most were taken in JPG mode.
http://justtakingpictures.smugmug.c...searchType=InUser&NickName=JustTakingPictures
Thanks again.
After I reimport 99% of my photos, then copying and pasting the metadata/adjustments from each photo to the newly imported one, I discovered something that would have saved a ton of time. Instead of having to reimport all of them. You only have to import one. All the metadata/adjustments/ratings are still in the original DNGs from Aperture 1.5. In Aperture 2, it just doesn't recognize it because it needs to be decoded in the Raw2.1 format. If it doesn't display correctly, you don't have the option to change the decoding method.
If you copy the adjustments from a newly imported DNG file, even without any adjustments. Then pasted it into the other older DNG files that are already in Aperture, it will work. Even if you pasted into 50+ DNG files that already exist, they will now display correctly (instead of the unsupported format error). All the older metadata/adjustments/ratings will stay just like the original. You can probably search all photos with the keyword DNG, and paste the new adjustment into all of them. I know it works for all DNGs in one projects.
This would have saved me weeks of reimporting then copying and pasting each individual photo adjustment/metadata/rating. :bang:
Hope this helps others....
If it doesn't work,send me an email or posting and I can walk you through it.
