Rear curtain sync on the Bessa R possible
Anupam
9:03 PM
This is probably not possible but doesn't hurt to ask. Is there any way to make the Bessa R fire the flash to sync with the rear curtain - i.e. at the end instead of at the start of exposure?
If it matters, my flash is a Nikon SB-28.
Thanks,
-Anupam
With the SB-28 rear curtain sync is definitely not possible - you can't set it on the flash and you can't set it on the camera.
With some older Nikon flashlights (SB-26?) it was possible to set rear curtain sync on the flash - but I doubt anyway it would work with the Bessa.
Michael
That's what I was expecting. Thanks. I'll have to hold onto the N90s body for the few times I really need to do fancy flash work.
-A
The Tailflash only works for Leaf shutters, so that won't work for the Bessa R.
You can get a Pocket Wizard Multimax transceiver, which has programmable flash delay to emulate 2nd curtain sync, but one Pocket Wizard is going to cost you more than the Bessa R or the N90s.
Interesting stuff. But not worth it for my limited needs. I'll just pull out the SLR when I need fancy flash work.
Thanks,
-A
