grouchos_tash
I got my 'fully functioning, excellent condition' Fed 2 sooner than I thought. The shutter is slooooooooooooow. The rear curtain doesn't catch up until I leave go of the shutter release at all speeds apart from 1/500th. I've noticed there is a thread on here about adjusting the shutter but it this not just a lubrication issue? I thinking about trying to fix it myself before sending it back.
Sorry to hijack the thread but I thought this would be a good place for an answer
Greyscale
If you grew up in FSU you would know that they don't.![]()
Everyone wants to spoil my fun.
farlymac
PF McFarland
Sorry to hijack the thread but I thought this would be a good place for an answer![]()
Could be a lube issue. I'm beginning to think that "in working order" means there are no missing pieces.
PF
grouchos_tash
PF
Well, I tried to be a hero and service it myself :bang:
I ended up snapping the pin in the centre of the shutter selector. I guess the camera is dead now unless people have other solutions that don't cost more than a working replacement?
radi(c)al_cam
I ended up snapping the pin in the centre of the shutter selector. I guess the camera is dead now unless people have other solutions that don't cost more than a working replacement?![]()
edit: http://bfy.tw/83Ok
grouchos_tash
this pin shown here http://www.pentax-manuals.com/repairs/fed2service.pdf on page 3?
edit: http://bfy.tw/83Ok![]()
That's the one
radi(c)al_cam
That's the one![]()
I was confused because IMHO, this pin looks indestructible, but of course it's just my visual impression.
grouchos_tash
I was confused because IMHO, this pin looks indestructible, but of course it's just my visual impression.![]()
I must have just over tightened it and it just came off in my hand, with the rest of it still screwed in place and out of reach. I guess a man must know his limitations.
farlymac
PF McFarland
Ouch! Maybe you can find a non-working one for parts. Or maybe it would be easier to fix than the one you have now.
PF
grouchos_tash
PF
I wonder if I can glue to back together without sticking up the spring etc hmm...
petronius
seany65
Groucho, according to a pdf fed 2 instruction manual I downloaded from butkus, when you take the back off, asnd look underneath the camera, there are four screws which are used to when altering the speed of the curtains:
"FED-2 Instruction manual
– 6 –
You’ll need to do the following: (look at the picture) open the bottom, you’ll see 4 bolts.
You can regulate the first curtain (it opens the shutter) with the bolts 1 and 2. The bolts 3 and 4 are for the second curtain (it closes the shutter). The bolt 1 and 3 are for fixing, the bolt 2 and 4 are for regulation of the curtains. Take off the lens, put the shutter speed in position “B”, cock a lever and press a shutter button. Look at which of the curtains moves slowly.
For example, the second curtain (it closes the shutter) moves slowly. In that case you need to unscrew the bolt 3, and turn around one or twice the bolt 4 (anticlockwise).
For example two, the second curtain (it closes the shutter) moves quickly. In that case you need to unscrew the bolt 3, and turn the bolt 4 (clockwise) once or twice. This method is used for all Leica type cameras, Zorki and FED"
'Bolts' 1 and 3 are the ones with the flanges, 'bolt' 1 is nearest the front of the camera.
I don't know about the front curtain.
I'd post the pic but I don't know how to get a pic from a pdf.
grouchos_tash
– 6 –
Thanks for the advice Seany65, but I've already broken the camera haha
seany65
But you'll know for next time, eh?
farlymac
PF McFarland
Checking out my Jupiter-8 2/50, and Jupiter-12 2.8/35 lenses on some Kodak Ektar 100 while driving around Giles, Craig, and Roanoke counties.
The shutter on the Zorki-6 camera still needs some adjustment, as it is running fast, and uneven. Not good for the Ektar film, which has only a little bit of latitude. Made for some great saturated images though.
Jupiter-12 2.8/35
Moon Jumping Training Camp by P F McFarland, on Flickr
Gravel Hill Christian Church Founded 1835 by P F McFarland, on Flickr
Through The Tree by P F McFarland, on Flickr
Jupiter-8 2/50
Trout Fishing In Roanoke by P F McFarland, on Flickr
Allegiant Liftoff by P F McFarland, on Flickr
Wormy by P F McFarland, on Flickr
See all 27 photos at https://flic.kr/s/aHskFdiHGs
PF
Jupiter-12 2.8/35
Jupiter-8 2/50
PF
maryland_fotos
In celebration, here's my first foray into RedOctoberLand.
36370010 by Maryland Photos, on Flickr
Kiev 4M, Helios 103, Kodak Gold 200.
julio1fer
The Helios-103 is a good instrument to make your exploration.
nukecoke
⚛Yashica
Parallel Universe
Shot on Fujicolor C100 with Industar-61 + Bessa-R, developed in Tetenal C41
(Sorry the Bessa-R is a cheat, but I-61 is a capable lens to use in Oktober chill - the valve handle shaped focus ring is nice to use with gloves on
