__
Guest
Post deleted by author request.
ZeissFan said:You can do collimating at home using an SLR, a telephoto lens (the longer, the better) and two tripods.
Keep in mind that calibrating a rangefinder and collimating a lens are separate steps. However, if the rangefinder system isn't working as designed, then you will get focusing errors.
Generally, if you suspect problems, you need to collimate the lens and calibrate the rangefinder and then test by focusing on objects at various distances and confirm that the calibration is in synch by inspecting the image on ground glass (or frosted tape) across the film plane. Set the shutter to B or T and keep it open. Obviously, this step becomes impossible with a Leica screw mount camera.
Here's my collimating instructions: http://elekm.net/zeiss/repair/collimate/ -- there are many others on the Internet using similar methods. This is what works for me.
ZeissFan said:Obviously, this step becomes impossible with a Leica screw mount camera.
greyhoundman said:You can't see the film gate area.
