resetting M2 frame counter
katgut@earthlink.net
2:27 AM
I never seem to get this right. When you load film and close it up, what frame number do you start on--38, 39? When I load the cassette and spool, I don't do any winding until I close the back. So the real question is, how many full winds are necessary to advance to the 1st frame?
thanks
i want to know the number of frames exposed, so i set the counter to zero. habit, is all.
you go, katgut ... set the wheel to numero one ... i've got yer back
I haven't read the instructions in years (they are around here someplace), and I seem to recall they say to set the counter to minus 2 and wind 3 times, to number 1. Moi, I set to minus 2 and wind twice.
Rob, look at the beginning of a processed film. You'll see slightly more than two frames' worth blank. I'm a miser and use that bit of emulsion.
I love the instructions for old cameras. They worked hard to fill 10-12 pages. The Nikon D3 instruction manual is 400+ pages!!!!
I don't think I have read a Leica manual since the early 60's - and that was a desperate situation - stuck in a hotel with nothing to read and by chance a M2 manual had been used to wrap around a lens as a "protective" sleeve.
I bulk load with the outstretchd hands method of measuring. Sometimes I get a 37th frame. Before I cut the film I look at it to see what's there. Often as not there's a frame in the right place to just discard one out of the middle of the roll. If not I cut it into 5 strips of five frames and 2 of 6 frames.
