Ricoh GR Digital GAS
Griffin
Grampa's cameras user
6:39 PM
Getting serious GAS for a Ricoh GR Digital. The 1 might be within reach, but is it good enough? DPReview kind of turned me off, but I wouldn't mind using it as a B&W only camera.
How are the other GR's?
Can somebody talk me out of it?
forget DPReview (not just for this camera)
The GRD is THE compact for serious photography, and for people who don't mind the prime-lens.
original GRD is the best for BW work I know, i 'grain like triX' in a good 'non-digital' way.
otherwise the GRDIII or IV are great choice with slightly brighter lens, and better hi-iso.
all of them are great, maybe spare the GRDII it's the less popular of them all
a decent one can be had around 180-200 $, a IV used around 350.- that's ok for what you get.
best
maitani
Most useful camera that I have by a long way.
Thanks for the replies all. I'm not much of a RAW processor, can I just fumble around with jpg's from the 1?
I've had a GR Digital since 2006 and it's possibly the best digital camera I've ever owned.
It's small and light, you can stick it in your pocket and take it anywhere, but it's not flimsy.
The battery holds its charge when not in use, unlike many cameras I've owned which will drain a battery dead within a week even when switched off!
You can configure the camera how you want it, then save the settings. The GRD1 and 2 had two setting slots, I believe the 3 and 4 have three slots. With the GRD1 you have to go into the menus to select which setting you want the camera to power up in, later models have the selection on the control wheel.
I've got mine so that setting 1 is 400ISO black and white 'snapshot' fixed focus, and setting 2 is 64ISO colour.
The problem with the GRD1 is that it's very slow at saving raw files. Mine takes about 15 seconds during which time it shows the last image with the caption "RECORDING". So I just shoot JPEG most of the time.
These are a few out of the camera jpegs...
Texture by Antony J Shepherd, on Flickr
or, in colour
Autumnal Colour by Antony J Shepherd, on Flickr
Note that a GRD1 won't take SDHC cards (I just tried that).
Also, mine has started to suffer from the problem where using the Adjust wheel makes the firmware crash, and I need to switch the camera off and on again to make it work. That's something else you'd need to look out for on a GRD1.
I've owned 2 GRD's, a GRD 2 and GRD 3, both were fantastic cameras and I always will make it a point to get another one eventually. The interface and build alone is enough to warrant them.
fwiw, it's the only digital camera that I regret getting rid of. I had the grd1 and it was the raw save times that killed it for me. I'm hoping one of the newer ones finds it's way to me one of these days.
Haven't tried the later ones but the original GRD is my favorite digital camera ever. Still works fine, six years later. I love shooting at ISO 800, e.g.:
ISO 200:
All JPEGs, and then nothing but channel mixer+curves in PS. Never even tried RAW on this camera (never felt the need for it).
That`s what I do....never felt the need to try RAW either.
Its always set on Snap focus too.
In the UK the GRD 1 goes for around a hundred quid....for what it does you can`t go wrong at that price.
I had to check where you were from, this guy looks so much like a good friend of mine, thought it was him at first.
No one here will talk you out of it. And if you can justify the expense, the low light capabilities of the III or IV will make you forget the debt. Some instruments are priceless-- what they do invalidates their cost. By that measure, the GRDs are a lot more priceless than say the Leica MM. But I'm being whimsical in my logic here. Just get the latest one you can afford and explore it.
So rather than talk me out of it I'm being encouraged to go into debt and buy the newer version... :eek:
Go for it, GRD is a lovely camera. I recently bought a X100 for better IQ but I'm not getting rid of my GRDIII for sure... unless I'd be buying an updated version. To good to get rid of.
Sorry for not talking you out of it :angel:
