chris00nj
Young Luddite
BTW Chris00nj -- great shots of Italy on your Flickr account. Gorgeous stuff. Very inspiring, considering I'll be re-tracing your footsteps in about one week! 🙂
Thank you for the kind remarks.
The 21 - 35 - 50 setup with the Ikon/ Bessa would be my suggestion. Do you have a Zeiss Ikon and a Bessa R3a? i'm wasn't sure from your posts. I've never seen a Contax G1/2, but if it is heavier, it will be more difficult. Walking in the heat in Italy will make you want to not carry a lot of weight. Autofocus isn't a big plus when you are in the sunshine and have wider angles.
I sometimes felt the 21 was a little too wide for a "walkaround lens", and I had a big gap in between the 21 and the 50. The 35 will be a nice addition. These lenses are small enough that taking 3 won't be a big weight.
Negative film will be less stressful, because you always can err on the side of overexposure and have a perfect print. I found myself fussing a lot over slide film exposure adding unnecessary stress to a vacation that is supposed to be relaxing. (Except for a couple test rolls, it was my first outing with slide film). If you don't have a lot of experience with slide film, I would only take a couple rolls.
