VF101
I've got an Epson Perfection V330 Photo scanner. I'm very pleased so far with the results using the Epson Scan software that came with the scanner. Now I tried the demo editions of Silverfast and Vuescan, hoping to get even better images.
Epson Scan
Silverfast
Vuescan
flickr Set Scansoftware
All scans were done with 2400dpi, using the default sharpening the scanner software did offer. Any other "enhancements", especially noise reduction, have been set off. 100% crops.
I'm really disappointed by the results I got from Vuescan, because I heard a lot of good things about it. Silverfast is a mess to use, but the results are good - at least with color negative film. Using b&w film, the Silverfast scan had to much contrast and was worse than the result from Epson scan software. (You can see the b&w scans in my flickr set.)
Do you have any ideas why Vuescan result is so soft and blurry?
So, I think it's not worth to buy any specialized scan software. Epson software not always gives the best results, but they are good enough for my intended usage.
Epson Scan
Silverfast
Vuescan
