scanning preference
The key is also to have the right scanning software. If you use the scanner vendor's software, generally you'll get less-than-stellar results, specially since all the "easy" features are 24-bit (i.e. 8 bit per channel). If you use a really nice scanning program, like SilverFast, using 16-bit, most of the time you'll find yourself having to do very little tweaking during scan time, and doing your tweaking post-scanning later.
A stitch in time saves a pint.
