Scanning with a digital camera
Maybe better word is "thinks to start struggling". It's a bit softer on your image. "Also, grain resolution. In this, full frame wins by a little." -- your words too.
As for corner details we can use grain.
That's great. Corners look better than center. It's a very good lens. Are both images on a same focus plane or best focus was used?
24MP is nothing for that lens. It can work on 100MP APS-C. To proove that you can use telecovertor or two. At least in the center.
OK, we are thinking and seeing about the same.
With my Pakon at 6MPx, no visible grain. At 24MPx with cam-scan, there's lots of visible grain, it's a good indicator of whether you are getting all the image detail that's on the film. But, now I am not sure what to do with it. Default capture sharpening is probably accentuating the grain, and it can produce strange patterns. So, still working on this, but happy when my lenses resolve it.
Yes, the corner is better than the center for the FF USAF target image. That's an anomaly, probably a very slight focus change from center shot to corner. I did my best to hold the same film plane and focus. These tests are difficult to do precisely without real lab-quality equipment.
Yes, this 70 f/2.8 Sigma Macro ART is far better than 24MPx FF (about 6 microns pixel pitch). That's evident when we see it performs well on 24MPx APS with about 4 microns pixel pitch. Could it deliver on 100MPx FF? That would be 3 micro pitch. Would love to see it.
Very interesting. Your results are very consistent with what I get with best lenses on Sony 24MPx APS bodies at 1:1.5 and at 1:1. I get a little more resolution, just about proportional to the increased MPx and reduces pixel pitch. These results for 90 Sony macro, 70 f/2.8 Sigma Macro ART, 55 f/2.8 Micro-Nikkor AI, and so forth.
I believe all these lenses and your Magnagon are limited by the sensors in our tests.
It's interesting how the stop sign and DHL logo almost look brown but the HSBC red looks red. The scan looks correct overall though.
It is. I don't see it as brown but a deep red on my calibrated monitor. The warning signs with the red surround in the sunlight are much redder, so I think the shade has something to do with it. Plus the film type (expired Fuji Pro160s from 2008).
I have other images where it turns a cardinal red into a purple. All the other colours are 'correct' so I think it is just a characteristic of this film and age of it.
Nikon F4, 50 1.4D, Fuji Pro160S, Z7scan, negativelabpro.com, garbage noise from flickr as the original is much cleaner...
I am currently struggling with scanning about 13 rolls of 35mm film. My Coolscan has been acting up, but for the most part is acceptable. I really appreciate everyone sharing their setups since I don't believe that this scanner will last more than another year or so.
I've got a shopping list ready - but I'll make sure to check in before I order since it seems that there are steady advances in the techniques (and equipment) used.
Thanks, everyone!
My Coolscan has been acting up, but for the most part is acceptable. ...
First, Frank Phillips can probably fix your scanner or call in Gleb Stengel for certain parts. Seller Nikon_Coolscan on eBay, or find him on FaceBook.
Camera-scan setups vary.
Horizontal: Easiest is a good bellows and film/slide copy holder. Nikon PB-4 for example. Macro lens. Flash or a good high CRI source.
Front of camera: Nikon ES-2 or similar. Looks easy; haven't tried.
Vertical: You'll want a very rigid copy stand, negative holder, diffuser, and light source. Some way to hold everything in place.
Hope this is helpful.
