Shallow Depth of Field in Landscapes
Has the use of the bokeh aesthetic got any place in daylight landscape photography?
To me, yeah why not? Why does everything always have to be in focus in a landscape image...? Use of shallow depth of field in a creative way in any type of image just can enhance things.. Its up to the photographer to find a way to use it..
I don't know about bokeh aesthetic, but I often shoot wide open landscapes or details where the landscape background dominates. Much less than stopped down, though.
Uncanny that you have posted this, Stewart, as, on the way home from work, I was thinking about the very same thing.
To make use of any shallow DOF in landscapes, I suppose there would have to be some fore/middle ground interest. Otherwise, you're going to end up with a bog standard image that arguably may not be as sharp as it would be at a smaller aperture*
I think.
Its something I've been mulling for a while. Admittedly, I am a shallow DOF/bokeh whore, so its inevitable that, if I were to dabble in landscapes, I'd have to at least consider this.
*dependant on speed of selected lens
It seems that contemporary landscape photography quite focuses on digital and high-res (plus pixel peeping), so : IMO, no.
Yet, I'd like to discover something else...
To me, as a viewer, a shallow DOF image is categorically NOT a "landscape" picture. It's a picture of an isolated subject, while the out of focus areas are simply framing and offering a background for the subject.
Landscape images are categorically huge DOF, so my eye can wander around the entire (in-focus) frame, just as it would had I been at the scene.
Wide open type bokeh, for me, very, very rarely. Like this:
35mm, f5.6 type bokeh more often. Like this:
(hard to see in the tiny jpg, but very nice 3D effect when hanging in 14x20 on the wall)
Roland.
I'd disagree with Dave. I think you can shoot shallow using a telephoto and still have enough depth to give enough form, sense of the place and eye-food whilst concentrating the initial focus of the viewers eye to one particular spot of plane.
Whether you as a viewer like or appreciate this is another thing
Hmm. I consider 'landscape' to be a bit broader than that definition.
Landscape to me is something with wideview at some distance. Flowers close up picture above isn't the landscape, IMO.
The tree standing in the field at some distance and taken on LF with wide open aperture and some shifts enabled would be perfect example of landscape bokeh, but I'm still working on it 🙂
Well .... after reading on here, I see that mine was kind of a weak reply. I was imagining an image of a {flower, statue, cow, car?} in perfect focus, surrounded by "bokeh" that shows form but very little detail. Some of the landscape examples posted above show me that I was not thinking broadly enough.
Good question to consider. "Landscape" to me implies a lot of depth, rendered sharp. The American West usually has a lot of light when I shoot, and the limited shutter speeds of my vintage cameras and Tri-X usually means f/11. I use a processor and shoot at box ISO speed. Depth is a result.
Still, it's a useful exercise to look at what others try to do.
