Does it already qualify as "old"?
Rollei 35S, Adox CMS20II
It's old enough, I had mine until 2012 and it was a classic then! Those US spec bumpers somewhat ruin the utter gorgeousness of the Michelotti design though.
^^ 1957-ish Corvette getting some attention! ^^
Buick Eight, 1950-ish OHV in-line eight motor, Dynaflow fluid coupling “automatic” transmission uses only top gear unless low is manually selected for special need. Bellevue, Washington. Can't ID that license plate...
Leica Q
Intresting, Larry... The sculpturing along the side looks quite different between the two. Grille is different, turn signals... Is that you gazing at the camera? 🙂
haha... probably not the only car have that 'feature'. As I think I recall, the Sunbeam Tiger required diving under the dashboard to reach the rear spark plugs of its Ford v8.Doug, as I recall, that Continental required that the engine be pulled in order to change the spark plugs!
- Murray
Mike, Do you think this guy trying to intimidate other drivers?
