Every FED 2 I have ever worked with synced with electronic flash just fine at 1/30. Are there some that don't?
Dez
Indeed your flash will fire, but not at the right moment; non of the FED 2 I had for servicing were synchronized for x, only for bulb flash. x-flash was an extra feature on some zorki's like the Z5 and Z6. There is no synchonization mechanism built into the FED 2.
There is something strange here, I assure you that the FED 2 in the picture is correctly synchronized for electronic flash, and reliably exposes the entire frame. To the best of my knowledge, I have never worked on the sync mechanism of this camera.
It makes sense that a camera with non-adjustable sync from this period would be correct for flashbulbs rather than electronic flash, but there it is.
z-4, j-9, j-3, j-12, i-12, i-50, universal viewfinder, soviet polarizing filters PF-42 & PF-49
Ron,Indeed your flash will fire, but not at the right moment; non of the FED 2 I had for servicing were synchronized for x, only for bulb flash. x-flash was an extra feature on some zorki's like the Z5 and Z6. There is no synchonization mechanism built into the FED 2.
Ron,
That's interesting because the two FED 2s I have used (1 sold and 1 still owned) are most definitely synched at 1/30th for electronic flash. One strange thing about FED's synch mechanism is that it works correctly only at 1/30 and at no other speed (even on models with slow speeds), not even on "B". In contrast, the Zorki 3S, 4 and 4K had a proper synchroniser that works correctly at all speeds of 1/30 and slower, including "B" and those without slow speeds also do work properly on "B".
I can recommend Aki Asahi's double-layer cloth. Excellent quality and stable in both directions. I've re-shuttered a FED 1 and Zorki 3M with it. It comes with a thin shutter tape which is deceptively strong.Very nice! I have one FED-2 in the same state of disassembly to replace the shutters, but I'm waiting to find a suitable material. I ought to take some photos 🙂
Love that demolition shot!
And that's really good FED and those chrome plates looks really sharp (new overlay or just good cleaning?).
Soviet polarizing filters... 😛😛🙄🙄
