d.dulin
I also found this, https://www.ebay.com/itm/Leica-IIIB-SM-Cameras-Outer-Shell-Body-With-Leatherette-Genuine-Parts-/302599435815 I wonder if it could be used on a iid body as long as the slow speeds portion is covered?
I also found this, https://www.ebay.com/itm/Leica-IIIB...-With-Leatherette-Genuine-Parts-/302599435815 I wonder if it could be used on a iid body as long as the slow speeds portion is covered?
I did want to have mine covered in grip tac but couldn’t bring myself to get rid of the original covering because it’s in such good condition, but if I do the iii she’ll i wouldn’t have any qualms with covering it in grip tac.
How involved is swapping the shell? If nothing but the lens mount and body screws have to be removed I may even do it myself.
Modern film canisters are about 2 mm shorter than those used when the I, II or early III camera models were made. However, you can use modern, shorter film canister with the help of a thin plastic ring that pushed the film canister in direction of the top plate.
If you use reloadable Leitz FILCA film canister (which only fit screwmount Leicas) the problem also will be solved since those are of the correct length.
Hi, regarding using a thin plastic ring (~2mm in thickness?), should I mount the plastic ring on the bottom plate such that the film canister is pushed towards the top plate? Just acquired a "hockey stick" Leica I, and have no clue about incompatibility of canisters.
Thank you in advance!
I use a thin Teflon ring of ~ 1.5 mm thickness that I put on top of the film canister before mounting the base plate. It just needs to push the film canister up.
EDIT: The film canister are only incompatible in the way that you cannot use old (longer) FILCA canister in M Leicas. The shorter film canister work in the old screwmount Leicas but part of the frame can be shifted into the sprocket hole area.
I think I’ve found the solution I’d be happier with, it involves removing the factory washer under the center screw for the on/off lever and replacing it with one that is wider in diameter to hold the film up
I ended up drilling a hole in a penny (US) about 1.8mm thick and installing it in place of the original washer. I’ll let you all know if it worked once I shoot another roll
Kevin,
From what others have said it goes on the bottom plate, which is where I put mine. I’ll hopefully run a roll through it soon to see how well it worked
