Show us your SLR ..... WHAT?
Picked up this baby locally for a nice deal! Seems like the aperture blades are sticky on the 38mm lens though. Any advice on cleaning them?
You're correct. It was canons' first solution for TTL Metering
Interestingly Sony uses pellicle mirror tech for its lower-end DSLR cameras, which they dub SLT. This is used in conjunction with their EVF system.
It gives you a WYSIWYG view, but a downside is that if you're using a manual flash, you're seeing the pre-flash results in the viewfinder and sometimes you can't see well enough to frame the shot. It's running in stopped down mode ALL THE TIME.
You may want to read up into recent Sony cameras. The top-of-the-line A99 and A77 also use this technology.
You can easily overcome the problem you have with the dark viewfinder by going into your menu settings and set "Live View Display" to off (at least with recent cameras). Sometimes big business listens to customers 😉
oh man if you have lenses with metal focusing grip to pair with wow...
nevertheless this is an awesome pair 😎
Do you mean those older S/H lenses? Never owned any of those.
The chrome w/ the 50/1.4 was my dad's old set-up which is now really a shelf queen that sits next to my beater black F2. I still run a roll in it every once in awhile to make sure it still works, but the 50/1.4 has some haze in it so I dont use it anymore.
yes enero, well just to make it an all metal combination 😀
btw, you've just triggered my gas sickness again...:bang:
